Help with amplifier and speakers options
nickt9999
I am looking for some help and suggestions on what amp and speakers I should buy.
Recommendations for the amp are Yamaha RX-V473, RX-V573 with Cambridge Audio Minx speakers
Does anyone else have any suggestions?
Thanks in advance
PSM1
Do you have any restrictions in terms of speaker or receiver size?
What is your max budget?
PSM1
With that budget I would look at the Q Acoustics 2000 AV speaker package instead of the minx. Your choice of receiver are good solid ones. Could also look at the Onkyo 515 or Denon 1613
thedude
Go with the sony range of new amps they are fantastic. And great value for money. They also sound less harsh than that of there cheaper japanese counter parts
PSM1
I would choose the QAs because they are conventional sized standmounts so will sound better than a sub/sat system for the same money. The QAs will get down to 80Hz which means the sub will not be able to be localised soshould give a more seamless sound. I you are not restricted in speaker size then I would not go for a sub/sat system as they will always be compromised in terms of sound quality compared to conventional speakers of the same price.
