Help with alternave refresh rates
Discussion in 'Desktop & Laptop Computers Forum' started by KraGorn, Nov 20, 2004.
  1. KraGorn
    KraGorn
    Aug 30, 2003
    4,740
    68
    Warrington
    +27
    While I've had an HTPC for some time I've never tried fiddling with changing the refresh rate from the 60hz default, using Powerstrip solely for setting resolution. I thought I'd try seeing if I could get 50Hz for PAL .. well I can, sort of.
    I have an ATI R9700 using Catalyst 4.10 driving a Sharp Z200E via DVI, this gives me 60Hz only according to the Display Properties. I use AnyDVD to handle multi-regioning and it comes with a feature that can run a utility to set the refresh rate based on the type of DVD inserted, ie. NTSC or PAL.
    However, when I try to run this for any value other than 60Hz it displays a dialog saying it couldn't set the frequency I want, eg. 50.
    I installed Powerstrip and find that it CAN be used to set 50Hz, a fact confirmed by Reclock .. I'm not using Reclock at all at the moment, I just ran it to get the true value of the refresh as Display Properties lies and still says 60.
    So, PStrip can set 50 but not AnyDVD's utility. Okay I though, I'd set up 2 PStrip configs and toggle between them, a bit of a pain when mixing NTSC and PAL DVDs but I'm sure I can automate it given time. Sadly this is not to be, PStrip can't seem to store more than one setting per resolution.
    So I'm stuck, I can manually dial 50 or 60 into PStrip and it'll set it but that's more than a little tedious, but I see no other way of doing it. Am I doomed to being forced to use 60Hz all the time if I want to use DVI? I haven't tested it but I assume if I switched to VGA then I wouldn't be locked into 60Hz by Windows.
  2. Muf
    Muf
    Sep 11, 2003
    412
    IRL
    +8
    Hi KraGorn, You can set up different Refresh rates for the same resolution in Power strip. Have a look at the thread "Picture refresh rate on projectors" in the "DLP and LCD Projectors Forum, last post by myself on Nov 1st 2004. I can't generate a link, sorry.
    Jim.
  3. drummerjohn
    drummerjohn
    Sep 2, 2001
    2,465
    Southampton
    +186
    Kragorn, I dont thin you can do 50Hz over DVI.
    I, however, use AnyDVD as you have tried to change the powerstrip settings. I wrote some batch files for 50Hz and 60Hz that AnyDVD uses to change powerstrip and even the player. I use Zoomplayer for 50Hz (which is 95% of my DVDs) and TT for 60Hz.
    When I get some time I will post them here tonight I hope to let you have a look at. They may give you some ideas.
  4. KraGorn
    KraGorn
    Aug 30, 2003
    4,740
    68
    Warrington
    +27
    Muf: :suicide: .. I posted in that thread but I never saw your last reply to me :blush: .. that link tells me exactly what I need to know.
    John: I'm certainly getting 50Hz to the projector, I discovered an 'info' menu item on the Sharp and it does show it receiving 50Hz when I manually set Powerstrip to that value. I'd appreciate seeing your batch files to see what you managed to do with AnyDVD that I didn't.
    Cheers both. :smashin:
  5. KraGorn
    KraGorn
    Aug 30, 2003
    4,740
    68
    Warrington
    +27
    Muf: the desktop shortcut method described in the link you provided works a treat, many thanks for that I doubt I'd have discovered that in a month of Sundays. :)
  6. drummerjohn
    drummerjohn
    Sep 2, 2001
    2,465
    Southampton
    +186
    Well thats good to hear that you got 50Hz out of DVI.
  7. KraGorn
    KraGorn
    Aug 30, 2003
    4,740
    68
    Warrington
    +27
    Whether it makes much difference is another matter. ;) I'm hoping that I can figure a way to use those shortcuts in the batch files you have, this is part of AnyDVD I've never played with.
