Help with Accent HT400 build and spec
Discussion in 'Desktop & Laptop Computers Forum' started by newstuart, Jun 2, 2005.
  1. newstuart
    Apr 22, 2004
    Hi, ive recently purchased a accent ht400 case with imon inside to build a htpc with. This is what the pc will do when finsihed,
    1)be used as DVD player
    2)be used with MCE or Imon as a front end for PVR,TV & music files etc
    3)Display will be a Daewoo low spec (non DVI input) plasma screen
    4)Amp is a Onkyo TX-DX 595 with built in decoder
    I want to use the amp for all decoding duties fed ideally via optical lead and feed the plasma via the standard pc input
    Im assuming because of this I will not need a high spec sound card or graphics card, is this correct ?
    I have seen this on ebay,
    its a motherboard with built in graphics and sound, I was wondering would this be adequate for my needs ?
    I also want to have twin freview cards fitted, any suggestions on these ? ideally reasonably cheap
    Other than that I allready have a dvd drive,hardrive and psu. is there anything else I will want ?
    Any tips or suggestions on how to do it differently are much appreciated
