Help with a thomson 643....
Discussion in 'General TV Discussions Forum' started by CyBeRkId2002, Aug 17, 2004.
  1. CyBeRkId2002
    CyBeRkId2002
    Mar 9, 2004
    2,709
    83
    +127
    Im having trouble getting this tv to work with RGB through my DVD player (philips dvdr70)... when i switch the dvd player on the pic comes on for a couple of seconds and then disappears....
    I believer the dvd waits for some kind of signal from the tv as to whether RGB is ok and if not reverts back to composite which it would appear to be doing. Had no problem with this on any other tv...
    Please tell me theirs a way around it :)
    Michael
  2. CyBeRkId2002
    CyBeRkId2002
    Mar 9, 2004
    2,709
    83
    +127
    has anyone had this or similar problems and can offer any advice?
