Help with a PWD6
Discussion in 'Plasma TVs Forum' started by darenc1967, Jun 10, 2004.
  1. darenc1967
    darenc1967
    Jan 31, 2004
    73
    The picture via component has gone green.
    I have checked other inputs and S-video and VGA are ok.
    The terminal board is still secure and I have reconnected the cables also connected the screen via the same cable directly to my dvd player and have the same problem.
    Is there anything else i can try I don't have another bnc- rca component lead to try, so i guess it is either the input board or the cable.
  2. jrpavel
    jrpavel
    Jan 25, 2004
    178
    16
    Check that the cables are OK, and connected to the right colours: I always find the Blue and Green quite hard to distinguish.
  3. jmack
    jmack
    have you selected rgb instead of component on the plasma?
    loose cable?
    my bet is the first one :smashin:
  4. darenc1967
    darenc1967
    Jan 31, 2004
    73
    JMack
    You're right I was playing arround in the setup before I noticed the green issue. Some how I set the input to RGB, I was quite concerned at the time hence the post.
    Disconnected all the cables etc for nothing. :rolleyes:
  5. jmack
    jmack
    do i win a price :smashin: :smashin:
  6. symanski
    symanski
    Jun 20, 2002
    874
    Scotland
    +8
    Sometimes, if you've got RGB with a dirty Green you can get a bright green picture as the screen is trying to zero to the green. Slightly off topic, but if you did introduce something with a dirty green, it's exactly the same.
    All the best,
    Dr John Sim.
