Hi everyone
I've recently boxed up my trusted yamaha 667 (which ive had 10years of good service from) and installed a Pioneer LX77.
I run a 5.1 system with a mordaunt centre, a yamaha sub and 4 beolab 6000's which are connected via specialist cables to the pre-outs of the amp.
Ive noticed some stark differences in setup and I am a bit stumped over some.
Firstly, the beolab speakers are individually amplified - this means that they power on when there is a sound source. For some reason I cannot explain, after a while of the receiver being off the speakers will turn on. This does not happen if the receiver is left on and the source is turned off. Never had an issue with the yamaha. Can anyone help me as to what is happening?
Secondly I am having an issue with content. I am on Virgin Media (recently left sky after 12 years) and I did manage to get a few weeks of content with it with the Yamaha, so I have a "decent" reference.
On the pioneer I noticed a lot of the content is output only to the front two speakers (the full 5.1 connections light up on the amp screen)
I never noticed this on the yamaha - reading up it seems perhaps the amp was quite succesful in extending stereo to the rear channels. When I select extended-stereo on the pio however i get a terribly flat two channel stereo playing from the side speakers.
The VM forum replies are that its a matter of content - hinting that the pio is underperforming a much older/cheaper amp in extending a two channel signal, but i somehow find that hard to beleive?
Lastly, i dont have the calibration mic for the pio. am i right in thinking using the yamaha YPAO isnt going to give me good results?
Thanks for all help you can provide!
F
F
