Help with a dvd player for JVC plasma.
Discussion in 'Plasma TVs' started by Tim Cooper, Jun 30, 2003.
  1. Tim Cooper
    Tim Cooper
    Sep 20, 2000
    2,773
    71
    Laindon Essex
    +96
    Hi all,
    My mate has a JVC AV42PD20ES plasma TV, what dvd player do you recommend? Bearing in mind that it can't do "progressive". I'm a HCPC user so i'm out of the loop so to speak, i haven't a clue on a good player.
    Budgets around £250-£300.
    Cheers.
    Tim.
  2. kocl
    kocl
    Jan 8, 2003
    591
    PORTUGAL
    +13
    Hi, i'm looking for the jvc plasma 30ES, but no one was able to tell anything about it. Can you describe your experience with your plasma.
  3. Tim Cooper
    Tim Cooper
    Sep 20, 2000
    2,773
    71
    Laindon Essex
    +96
    Hi Kocl,
    The plasma screen i mention is not mine, it's a friends he is very pleased with it.
    Cheers.
    Tim.
  4. wilber
    wilber
    Sep 29, 2002
    1,970
    +30
    Pioneer 656 - top player if you don't want prog scan, excellent picture through component (RGB scart come to that) added bonus of SACD & DVD-A compatible.
  5. Tim Cooper
    Tim Cooper
    Sep 20, 2000
    2,773
    71
    Laindon Essex
    +96
    Thanks Wilbur,
    Can anyone else recommend any other dvd players & where is the best place to buy?
    Cheers.
    Tim.
