Question Help with 7303 wall mount bracket etc.
Moolers
Any VESA mount that's meets the requirements of your set. What size 7303 is it? Do you want it to tilt and swivel or not. Plenty on Amazon to choose from.
SaveLoopy
50 inch, I want it to do the whole works. I'm fine if doesn't though. Anything you recommend?
Moolers
Any 200 x 200 vesa from Amazon will suffice. I've bought a handful over the years and all have been fine. These are light sets (no ambilight pun intended :) ) so you don't need to spend a fortune. I'd recommend one that sits as close to the wall as possible if you don't need motion.
