HElp with 5.1 systems and a mission m7 question
Discussion in 'Home Cinema Speakers' started by mikey2108, Jan 3, 2005.
  1. mikey2108
    mikey2108
    I Am just about to order my 5.1 speakers for my new setup and need a little advise, due to budget restrants I need to choose between the following, tannoy fx5.1 (£179.99) or mission m7s (£89.99) I have a denon 1705 amp and a toshiba 32wl48 on its way. Now my question is this which set should I go for? They will be used for home cinema only, and I need them to be wall mountable, which leads to my second question. Doesw any body know if these 2 speaker sets can be wall mounted? Help please I am pulling my hair out!! :lease:
  2. sparticus
    sparticus
    Nov 17, 2004
    228
    Manchester
    +8
    hi
    Mission m7s come with their own wall mountable brackets which are quite neat. However, the sound quality, was at least in my view terrible. Knew id made a mistake as soon as played a cd through them. No amount of tweaking changed this. Everyone I spoke too said they were better than the tannoys so god knows what they are like.
    hope this helps
  3. mikey2108
    mikey2108
    Thanks for the reply, Not quite sure what to go for now? If the missions are that bad! Also I cannot get a set of tannoy from anybody (all out of stock). Any other suggestions for a silver set of speakers at the same sort of money? I will only be using these for watching sky+ and dvd's?
