help with 4k picture settings
abtorque
hey guys wondering if anyone can help. I've just bought the Sony 55x8509c and I've tampered about with picture settings from all over the net. does anyone have the settings so I can calibrate it properly. the pic just seems to be slightly off, uneasy to the eye. I know there is different preferences and can make a difference with light in room etc but just an around good picture would be great. thanks
Recall
Established Member
I had the same issues with this TV. Most of it revolves are the live colour and incorrect colour profiles selected. - Hope this helps, your feedback is very welcome!
Set picture to Auto 24P make changes, the select standard picture and reselect Auto 24P
For TV / Netflix etc
Select standard in picture settings
  1. Brightness 35
  2. Contrast 90
  3. Gamma 0
  4. Black level 50
  5. Black adjust Medium
  6. Adv. Contrast Medium
  7. Colour - 55
  8. Colour temp - Warm
  9. Colour space - Auto
  10. Reality creation - Auto
  11. Random noise reduction - OFF
  12. Digital Noise reduction - OFF
  13. Live Colour - OFF
  14. Sharpness - 60
  15. Motionflow - Standard
FOOTBALL MODE
  1. Brightness 40
  2. Contrast 90
  3. Gamma -1
  4. Black level 50
  7. Colour - 55
  14. Sharpness - 60
  15. Motionflow - Smooth
For Movies /Blu Ray / Hi DEF ( not HD cable / sky )
Select Cinema Home in picture settings
  1. Brightness 35
  2. Contrast 90
  3. Gamma -2
  4. Black level 50
  5. Black adjust OFF
  6. Adv. Contrast OFF
  7. Colour - 50
  8. Colour temp - EXPERT 1
  10. Live Colour - OFF
  11. Sharpness - 50
  12. Random Noise reduction - OFF
  13. Digital noise reduction - OFF
  14. Reality Creation - Manual 20
  15. Mastered in 4k - ON
  16. Motionflow - True Cinema
GAMING
Everything at default, this mode is optimised to reduce lag and touching stuff defeats this.
abtorque
thanks alot for your time man :) , I will have a bash at them 2morrow and see ( the misses getting on at me now for neglecting her lol ) I will keep you posted though!
abtorque
yo buddy, them settings seem to have help a fair bit ....my maynnnn. cheers. quick question though, is ur tv shutting down fine? mines goes into standby fine but when I shut down it restarts itself. I've check all the settings etc just wondering if it's a software thing?
Amazon Fire TV Cube Gen 3 Review: Coming Soon
