HELP with 36fs76 Geometry
A
AV ADDICT
Please help.
Just got my tv and find that if i rotate the vertical into alignment then the horizontal part is out and vice versa.
Therefore I can't get both axes correct.
Also in the RGB menu I can't centralise the image perfectly.
Can anyone help me please?!!
Love,
KV
mh66639
Humn I don't recall having your problems with my two sets.
I needed to rotate "-1" and to center "-10" or "+10" on the RGB setup menu.
Do you need to rotate so much?
Matt.
A
AV ADDICT
Thanks for your reply.
I find that RGB =+10 still doesn't centralise a grid on my video essentials disk.-10 to 0 is definitely wrong 4 my tv.
The rotation is a problem. I can get either vertical correct or horizontal but not both.
It's worse to align vertical cos the horizontal lines then really result in a thck band on the right and thin on the left side of the screen.
Thus, I have compromised and aligned the horizontal so the black bands at least are of even thickness all the way across the screen.
Am I asking too much for the lines to be correct on a 36'' tv?
What do I do please?
KV
Samsung QN800B 8K TV Review
