Help with 32gb SD card
Fozzy17
Hi ive got a 32gb sd card that i use in my gopro, when i was away my sisters kids were messing about with it, maybe by putting the sd card in another camera, anyway i used my gopro today and looked at the memory card and its 29mb in size, i tried formating it and nothing it stays the same, any help or ideas would be gratefule..
gagaga
Put it in a pc with vista or later
Click start, type cmd hit return
Type diskpart in the command window that pops up
List disk
Select disk x. ... Where x is the sd card careful as the next step deletes everything off the chosen disk
Clean
Create partition primary
Format fs=fat32 quick
Assign
Exit
... Should be back to normal then.
