Help with 24" shortlist
Discussion in 'Computer Peripherals & Consumables' started by Dr O, Feb 5, 2009.
  1. Dr O
    Dr O
    Dec 23, 2008
    430
    28
    Mucho Northo
    +71
    Not an area of expertise for me- though that list is small anyway;)
    Looking for an LCD monitor as have a CRT currently and thought it's about time to upgrade. Size wise 24" prob optimum unless someone suggests a specific larger one.
    Could prob spend up to £500 before justification would be required:rolleyes:. Will mainly be used for photo-editing and some video editing. Not interested in PC games. At some point in the future maybe or playstation but not worth considering- I am sure I could get buy.
    Models I have looked at are:
    HP LP2475W
    Dell 2408WFP A01
    Hazro HZ24W
    Benq FP241W
    Samsung SM245T (prob too dear)
    A bit of a minefield out there- keen to avoid 'TN' panels though I am not sure there would be much of a difference to me with IPS and PVA or S-PVA?
    Any thoughts on which of these would be more suited for me?
  2. Singh400
    Singh400
    Feb 21, 2006
    17,850
    Earth
    +3,370
    For video and photo editing. The only one I would even consider would be the Dell 2408WFP A01. It's the best monitor out there in terms of colour reproduction, infact it's spot on.
  3. Dr O
    Dr O
    Dec 23, 2008
    430
    28
    Mucho Northo
    +71
    Thanks for that- it was really between that and the HP I suppose. The HP does have better input lag but I guess it's then compromised elsewhere...you can never win!
  4. Dr O
    Dr O
    Dec 23, 2008
    430
    28
    Mucho Northo
    +71
    An additional thought I have had is a TV/monitor combo. IS it possible to buy a TV that can also be used as a monitor to good effect (esp for photo editing) or do the refresh rates etc make this a jack of all trades, master of none idea?
  5. rosscouk
    rosscouk
    Apr 19, 2006
    419
    +89
    I agonised for days between the dell and the hp, but as I do play FPS's from time to time, so I plumped for the hp. You can get it much cheaper on HP's site and I googled around and managed to get a 10% discount aswell, think I paid 350 ish for it so well chuffed.
  6. Geege
    Geege
    Jun 27, 2006
    2,974
    +430
    Have you considered the NEC MultiSync 24WMGX3, excellent 1920x1200 monitor currently £448 at Novatech
  7. Dr O
    Dr O
    Dec 23, 2008
    430
    28
    Mucho Northo
    +71
    I hadn't seen that one thanks- looks pretty good as well- this is what happens, choices, choices, choices :rotfl:;)
    Shortlist now HP, NEC, Dell
  8. Geege
    Geege
    Jun 27, 2006
    2,974
    +430
    I personally was going to go for the Dell 2408WFP A01 but read reviews about the poor input lag when playing fast action games, so decided on the NEC 24WMGX3 instead, I guess it depends what you want it for.
  9. fundy
    fundy
    Apr 3, 2006
    128
    Milton Keynes
    How much difference is there between the Benq Fp241W and the others recommended.
    The Benq seems to get decent reviews (although most are a few years old) and can now be picked up for £300.
    am looking to pick up 2 non TN 24" screens in the next mth or so, any one give me reason not to go with the Benq?
  10. b1ts
    b1ts
    Nov 5, 2008
    916
    28
    +43
    @Fundy
    Nope, can give you a reason TO go for Benq, I am using one right now and it is fantastic, admittedly I got this over a Dell at the time as A01 was promised but not appearing but having now compared with friends A01 Dell I cannot see any difference between them for photo editing.
    Play a few FPS and see no lag issues either.
  11. crossbow
    crossbow
    Nov 18, 2007
    1,832
    83
    S Oxfordshire
    +257
    As you'll be using it mainly for photo-editing, I reckon a quality monitor would be much more suitable than using one of those TV/monitor combos.
  12. Singh400
    Singh400
    Feb 21, 2006
    17,850
    Earth
    +3,370
    If you want good response times and no input lag get a TN panel...
  13. Saltank
    Saltank
    Sep 3, 2006
    29
    3
    +3
    the NEC does a decent job by having the lowest input lag possible on non-TN panel as well as incorporating good image quality. It's no IPS, but it's a lot better than TN. It's like the middle of the road thing.
  14. Dr O
    Dr O
    Dec 23, 2008
    430
    28
    Mucho Northo
    +71
    Yeah, I figured that would be the case...TV's pretty rubbish these days anyway;)
  15. Dr O
    Dr O
    Dec 23, 2008
    430
    28
    Mucho Northo
    +71
    I should stick to my orginal plan- the remit is for photo editing so lag should have no bearing for me really.
    I guess I'm more inclined for the Dell- Singh400 reckons it best matches my needs. The HP seems pretty good too though. The NEC is prob not for me.
    I'll compare the two again and have a ponder...;)
    Don't think we can do anymore, will let you know how I get on.
    Thanks all :thumbsup:
