help with 2 monitors /radeon 9700
Discussion in 'Desktop & Laptop Computers Forum' started by jmack, Apr 7, 2003.
  1. jmack
    jmack
    hi i am using a radeon 9700 with a flat screen tft as main monitor and my plasma as 2nd monitor (well trying) but they are acting as one big monitor , not the same on each display as that is what i want?
    can you help in non techie terms
    cheers
  2. rhinoman
    rhinoman
    Oct 31, 2000
    2,631
    71
    Herne Bay, Kent
    +33
    In control panel/display/settings uncheck the box that says "extend my windows desktop onto this monitor". Then go into the advanced/display and make sure both monitors are switched on and the clone display is selected.
  3. jmack
    jmack
    hi i cant find clone display. when i go into advance settings i get the radeon ati settings?
    help johns
  4. rhinoman
    rhinoman
    Oct 31, 2000
    2,631
    71
    Herne Bay, Kent
    +33
    If you go into the ATI control panel which is advanced in diplay settings, then choose the display tab you will get a screen showing 4 displays, too each display are two blue buttons, the circle in a circle makes that display the primary monitor (dscaler only works on the primary) and the other is the clone button. Select it and apply the change.
  5. jmack
    jmack
    thanks johns that worked but its showing as mulible monitors not secondary monitors so it wont let me apply different rez
  6. rhinoman
    rhinoman
    Oct 31, 2000
    2,631
    71
    Herne Bay, Kent
    +33
    I dont think that you can use different resolutions at the same time, the work around is to setup hotkeys to switch between resolution and primary monitors as required.
