Help: Wireless internet though computer Using XBMC?
C
cbradley857
:hiya:
I installed XBMC after softmodding my Xbox today, however, i would like to access the internet.
I have got a crossover cable from my Xbox to my computer, which has a [GOOGLE]BT Voyager 1055[/GOOGLE] connecting wirelessly to my hub.
I Can FTP between my Xbox and computer, but cannot access the internet
Please help me get online - Any help will be appreciated
Chris_J_0907
Have you turned on Internet Connection Sharing on your PC? I think you just need to do it on NIC, which the xbox is connected to.
C
cbradley857
ive tried it with the wireless adapter, but not with the crossover - ill try that now
C
cbradley857
no its not allowing me to change it
It comes up with a messege like this:
An error occured while interent connection sharing was being enabled.
Internet connection sharing cannot be enabled
A lan connection is already configured with the ip address required for automatic ip addressing
:S ***?
Sorry bout the double post
C
cbradley857
on second thought, i might just try to FIX my xbox first...:oops:
