Help will this work with magic Eye
Discussion in 'Satellite TV, Sky TV & FreeSat' started by Rookies, Oct 22, 2005.
  1. Rookies
    Rookies
    Jan 4, 2003
    5,681
    +542
    Ok Folks,
    I live in a newly built house in which at the same time there been a tv point built in 4 rooms (loung, Kitchen and both bedroom). They all run up to the Loft to a box that goes to the arial. What I though I could do is..... go in the loft and join together the cable that runs to the lounge socket and the cable that runs to the master bedroom socket. I then plug in a cable inthe back of sky + RF2 to the wall socket in the lounge. Then plug in a cable in the master bedroom then into the magic eye and then into the tv.
    Would this work?
    Please dont laugh as I am noob on this
  2. Rookies
    Rookies
    Jan 4, 2003
    5,681
    +542
    Anyone please help like to know before go shopping tmr
  3. blitzed
    blitzed
    Mar 14, 2005
    386
    28
    hayes
    +43
    hi m8,
    theres no reason y it shouldnt work only thing you might need is a distribution amplifier.
    the're made by global communications and work specially with sky, no power needed it gets it supply from the sky box cant remember which model ive got but u'll find loads on ebay.
    hope this helps.
    ed
