Help! - Which VCR?
Discussion in 'Digital TV & Video Players & Recorders' started by Chris1969, Dec 16, 2001.
Tags:
  1. Chris1969
    Chris1969
    I am finally sick of the poor quality of recording on my combined TV/video unit, and am upgrading to separate TV and video. I'm restricted to 14" TV, so am going for the Sony flatscreen version. But now I am totally baffled by the choice of VCR. I have cable TV, but as far as I am aware, no VCR will change channels for me to be able to record from more than one channel while I am out. Would I be best going for a Sony VCR (would it be easier to use with Sony TV), or what about S-VHS? Is the advantage worth the extra cash? Any advice gratefully received.
  2. Garrett
    Garrett
    Apr 21, 2001
    41,180
    2
    167
    The best thief you’ll never see.
    +7,093
    S-VHS on a 14inch TV I do not think you would notice the difference. I have a Panasonic that I think can switch the sat on if you place the sat over it, I never went into it as you can set the sat to come on by itself now. Can you do this with cable?
    Personally I do not use S-VHS on every thing only what is extremely important to me, but I find the reproduction very good, not in DVD class, but then again neither are transmissions. I think you can get a Panny S-VHS for about £200 pounds, JVC are also worth a look. I would go for a S-VHS if I was you as you never know when you might need it, i.e. great for archiving camcorder material if you decide to get one in a few years if you haven’t one now.
    :cool: Ruby quatz shades.
