Help!! Which DVD Player???
Discussion in 'Blu-ray & DVD Players & Recorders' started by chrisslade, Jun 10, 2005.
  1. chrisslade
    chrisslade
    I've recently got hold of an Hitachi 32PD5200 and want to find a suitable DVD player for it. The only other pieces of equipment plugged in are Sky box (RGB Scart) and computer (DVI, although don't mine using the D-sub connection instead). I need to be able to play both DVD-/+R, and would like to connect using either the DVI or Component connections. Budget upto about £200. I have considered the following so far:
    Pioneer 575
    Denon 1910
    Panasonic S97
    Samsung HD945
    Comments - or alternatives would be appreciated. :thumbsup:
