Help which DVD player to buy for Full HD
krs187uk
Joined
Apr 13, 2007
Messages
Reaction score
Points
2
Location
Manchester
I am updating my current setup and would like to know which is the better Player:
Denon 2910
Denon 1930
Samsung HD860
It will be feeding a new sony 40" Full HD screen.
Any advice would be great.
None of these machines will give you full HD. The most you will achieve is upscaling of DVDs. For full HD you will need an HD DVD or Blue Ray player and I wouldn't like to say which format will survive right now.
All the players you list will give you good results for DVD. If you are really interested in HD, either stick with the player you have a little longer and see what happens or don't spend too much on an ageing technology if you purchase a new DVD player.
To be honest my current dvd player is on it's way out and i can get the denon 2910 for 120 and the 1730 for 130 with 3 year warranty. Is the 2910 a decent player for that money?
Where can you get the 1930 for £130?
The 1730 is from richersounds at £139 with a 3 year warranty.
the 2910 is off a mate. I'm under the impression that the 2910 is a better dvd player but was wondering if the 1730 is just at good.
Perhaps it's worth spending £30 on one that will make do, and last 2 years, at which point perhaps the hd format war will be one and players will be cheaper (and will upscale your sd dvds as well) ?
Go for the 2910 definitely.
It makes loads of sense to get a great deal on a better 2nd hand player from a reputable source (even better that it's a mate), than to spend on a new lesser model. And for the money that's a bargain for the 2910. It wasn't that long ago it would have been around £300 for it 2nd hand.
T.
Cheers, i'll get the 2910 and fingers crossed everything should work.
Thanks for all your help!
The denon 1730 is very good as i have bought it not so long ago, picture is razor sharp and sound is good as well, i guess the 2910 is better but second hand is a risk. Now LG have come out in the states with a blue ray/HD hybrid player and it plays dvd's as well. It is selling for around 1200 US
That sounds like it's covering all bases. It's not the hardware that bother me though. I wouldn't buy one until the cost comes down and there are more titles available. It's more about buying into dead software. The last thing you would want is a shelf full of Blue Bay or HD DVD disks without any new players on the horizon.
Have been looking around at the DVD players and now i've found another 2 that look like they do a good job:
Sony DVP-NS76 Upscales to 1080i
Samsung HD 870 upscales to 1080i
So the big question do i buy either of the above or buy the denon 2910???
Any advice would be good as i will be buying one of them tomorrow.
Well it depends what you decide: better pic quality by buying the denon but risk second hand quality with no warranty or buy one of the other two but less pic quality.
I would probably go for the denon because i would want the best pic quality for the money.
It not very good though and have a lot of features missing for HD DVD such as the interactive stuff. The upcoming Samsung hybrid looks much more promising and is fully featured both HD DVD and Blu Ray.
RESTORATION vs. REVISIONISM: At what point do 4K video and audio 'upgrades' cross the line?
Back
