HELP!!! Which DVD player should I buy???
Discussion in 'Blu-ray & DVD Players & Recorders' started by samhassall, May 18, 2001.
  1. samhassall
    samhassall
    Since cancelling my order for a Toshiba SD210 from Techtronics, due to it now needing RCE prelim checks, I just don't know which DVD player to buy.
    Can anyone help?
    Requirements are as follows:
    Play RCE discs automatically, ie no work around tricks or disk swapping
    It must come in silver or champagne finnish
    Have an RGB output (Scart is fine)
    Not cost more that £300 fully modded
    From a reputable dealer like Techtronics or DVDmagic
    Should I wait for new models to come out i June/July, or go for something like a Sharp DV-760, JVC s42, or Pioneer 340?
    Thanks in advance!
  2. swartzy
    swartzy
    Apr 16, 2001
    9,493
    Northern Ireland
    +696
    Toshy,
    Worth checking if the Sony 336 (silver) model from techtronics plays R.C.E. automatically since this seems to meet your technical and budget requirements?(just a thought)......
    regards
    :)swartzy :)
