Help! What wall mount for Logik LCXW23NT4
Discussion in 'Home Cinema Buying & Building' started by John B Stev, Jun 7, 2005.
  1. John B Stev
    John B Stev
    I bought this 23" LCD from Currys, but they and their spares organisation seem unable to recommend what mount is compatible, despite their spec stating it is wall mountable! I assume it is not 75/100 VESA as there is a connector box attached to rear centre of TV and therefore no threads in suitable position. The only thread holes I can see are in corners which are 450m apart horizontally and 300m vertically. Hope someone can advise. Thanks.
  2. lee01
    lee01
    Feb 5, 2005
    151
    aberdeen
    hi go to currys wbsite then click on the Spares & Accessories link u mite get 1 from there
  3. John B Stev
    John B Stev
    Thanks Lee - but tried that! Partmaster is the spares organisation for the Dixons group and they literally said they could not help!
  4. lee01
    lee01
    Feb 5, 2005
    151
    aberdeen
    ok did they say the had no lcd brackets or none to fit ur tv
  5. John B Stev
    John B Stev
    They supply a range of LCD/Plasma brackets, but said they have none compatible with this model (which their own parent organisation are selling!)
