Help - What centre speaker?
Discussion in 'Home Cinema Speakers' started by Jockey, Jan 22, 2002.
  1. Jockey
    Jockey
    I've recently purchased the following system,
    Marantz SR4200
    Marantz DV4100ose
    Mission M74
    Mission 77ds
    & am looking to add a centre speaker to complete the setup. I listened to the 7c1 and didn't like it. I had hoped to add a 77c1, but can't track one down (richer sounds sold out their 99quid offer stock, as have a few other places I've tried).
    I am therefore looking for any suggestions as to a similar replacement (Tannoy Merc MC, Kef Q95.2C, B&W, etc.). Any help is greatly appreciated, as the centre is one of the final pieces in the jigsaw. Observations on sound, looks, compatibility with my system, etc. will all be considered carefully before I decide.
  2. Guest
    I have just replaced my 77c1 for B&w LCR60 S3. It looks and sounds better then the 77c1. Superfi will do you one for about £165
  3. Jockey
    Jockey
    I'll investigate. Any other options?
  4. Guest
    Only that the fronts should be timber matched ,meaning that they should be of the same make and design makup.
