help wanted on using cd wow voucher
Discussion in 'Shopping, Deals, Discounts & Bargains' started by tarpot's-daddyk, Nov 20, 2003.
  1. tarpot's-daddyk
    tarpot's-daddyk
    i've just got myself a voucher for cd wow using the trustcard site
    i've coppied the voucher code, clicked the link, but then i've opened cd wow hk the hong kong site right
    but the voucher doesnt work
    my thinking is that this site is a bit cheaper anyway so using the voucher i should be able to get this at a right knocked down price
    does anyone know if i'm flogging a dead horse here or is there a way around it
    regards
    keith
  2. Geezer
    Geezer
    Aug 5, 2002
    2,833
    68
    +25
    Im pretty sure you cant use them on th HK site
  3. tarpot's-daddyk
    tarpot's-daddyk
    that's a shame
    cheers
  4. figrin_dan
    figrin_dan
    Jan 9, 2003
    2,045
    +155
    Not sure if you still do it but I used to go through all the motions on the .com site and at the end choose HK dollars for that little bit extra off
  5. tarpot's-daddyk
    tarpot's-daddyk
    dont think it works like that because the hk dollar price will be the same as the uk price or doesnt it work like that
  6. TarPot
    TarPot
    Dec 16, 2002
    2,692
    103
    +269
    Good luck Keithyboy!
  7. tarpot's-daddyk
    tarpot's-daddyk
    You know its all good
    ended up ordering
    Peter Kay: Live At The Bolton Albert Halls for my dads christmas present fron hk version its still cheaper than using the voucher
    and i'll give that a good watch when he's finished with it :))))))
    i ordered it from tinternet
  8. JAMBO
    JAMBO
    You can't use vouchers on Hong Kong site. At the moment, the £ is very strong against the $US. Since the $HK is directly linked to the $US, you are getting a good exchange rate at present, so it may work out slightly cheaper. Nationwide credit cards don't charge an exchange commission, but most credit cards do, so depending on the exchange rate, any savings may be taken up in exchange rates or bank charges.
