spudgun01
I have a Videologic Digitheatre 5.1 decoder (not the DTS!) & amp (the amp is built into the Sub-Woofer).
I'm reasonably happy with it, but it does lack features such as being able to set delays to individual speakers.
So I'm in the market for a new decoder!
Would you recommend buying all new kit (decoder & amp) or just a decoder & plug into the amp - the subwoofer/amp has 6 inputs for such a senario.
I'm on a budget (who isnt!) and so can only spend upto £250 max - I don't need speakers.
I need a decoder cos my DVD player (Samsung 850) doesn't have 6 outputs, just an optical & coaxial out!
