J4g3d
Established Member
Just received this tv.
No wall mount screws OR spacers supplied.
Upon googling everyone is saying you must use M8 X 45MM bolts. WRONG WRONG WRONG.
The bottom holes need 15mm bolts.
The top holes seem to have a totally different thread to the regular wall mount bolts. And also 45mm is way WAYYY too long for this. I need a maximum 25mm bolts. Plus a spacer of 15mm. Or could I just bypass using a spacer? and just simply fit a 25mm bolt in instead? if so... What thread pattern is this using?
Appreciate any quick replies.
