Help Viewing Jpegs on DMR-E55EB-S!
Discussion in 'Blu-ray & DVD Players & Recorders' started by Primus, Apr 23, 2005.
  1. Primus
    Primus
    I have had my panny for a week now and I'm please as punch with it :D It is so impressive on the features side especially the Time Slip & Enhance Dialogue
    Anyway the one niggle that I have found is that I'm not able to make a CD-R/RW of pictures to view on the TV! is there anyway round this? if so I'm all ears, well eyes on the forum!
    Cheers,
  2. HMHB
    HMHB
    Nov 11, 2001
    25,517
    Nottinghamshire
    +3,852
    Unfortunately the E55 can't handle jpeg files. What you can do is make a DVD slideshow on a PC (assuming you have a DVD burner on your PC) - there are various software packages available to allow you to create a movie of your still pictures.
  3. ABP
    ABP
    You can make a VCD which will playback on your E55 but it must be VCD and not SVCD as I have done this for my Fathers E55.
    It was the only way I could get photos to display for him as I don't have a DVD burner.
    AB-P
  4. Primus
    Primus
    Thank you JohnG & AB-P,
    JohnG, I will be sure to try the DVD Slide Show option as I have everything on my PC that I require to do so.
    AB-P,I need a little more help from you if you don't mind as when I try to make a VCD my program only looks for MPEG1 files!! could you let me know how you made a VCD of pictures and what program you used?
    Kind regards,
  5. davee b
    davee b
    Jul 19, 2001
    236
    leeds
    if you are using nero just burn as a vcd compilation but drop in jpegs instead of mpeg1's. You can store about 1600 on one cd. :)
