Help: V-FORMAT set to NTSC on SD-220
Discussion in 'Blu-ray & DVD Players & Recorders' started by kevster, Jun 2, 2003.
  1. kevster
    kevster
    Apr 2, 2003
    10
    My multiregion Tosh SD220 (by Richer Sounds) is only 1 month old.
    Firmware is 1.5 - R2
    It played R2s and R1s no problem until recently.
    Now it plays R1 ok (they are NTSC) but any R2 (i.e. PAL) disc throws up a disc error message with "not NTSC".
    This does not appear to be region related as such. The V-FORMAT has changed from PAL/AUTO to NTSC when I view the status using zoom 606 zoom. Verison is still 1.5 - R2.
    Any idea how to set this back to PAL/AUTO. I did nothing other than power the unit off and on and press play......have only watched about 5 DVDs since purchasing.
    Thanks in advance, Kev
  2. S H A D O
    S H A D O
    Mar 16, 2001
    10,439
    United Kingdom
    +1,820
    Can you not just change it in the Setup Menu? It's the same menu where the Video Output, Audio Output settings etc are.
  3. fontyve
    fontyve
    Unfortunaly y have the pb and no solution ! I am going to get un other one
    but not Toshiba..
  4. fontyve
    fontyve
    the option in the set has disappeared!!
