KILLER NADS
Hi Guys,
Need some help in choosing the best parts to install in my current HTPC that i use for streaming movies to my 121" projector with XBMC and Blurays.
I am wanting to upgrade the system to a High-End Gaming machine, ready to play with my VR Kit (Oculus Rift) once it arrives in the next few weeks.
I want to be able to play all high end games such as Skyrim, Crysis 3, Bioshock Infinite on the best settings possible. Don't forget with the Oculus Rift, you are in sense displaying the game twice for 3D, so frame-rate needs to be try and remain high.
I dont in sense have a budget, can spend a few hundred if needed. But would like to spend as little as possible if i can.
Now my HTPC is a Assassins HTPC. Assassin HTPC -
The only things i feel that i need to upgrade are the RAM and GRAPHICS CARD.
As i am in a small shoebox case, i am quite restricted to the size of the graphics card. Hence, looking for the best one i can get in this case with this motherboard i have.
As the HTPC is in a Home Cinema Room, it needs to be reasonably quite operation and stay pretty cool! My current HTPC is really good at doing this currently, hardly makes noise and doesn't get very hot.
The cabinet it is in has some holes in the back for some air flow and also i try to leave the front half open (sliding door) when the HTPC is on.
Here is what my current spec is:
Shoebox Case
AsRock H77m-ITX motherboard
Intel i5 3570k
64GB Crucial SSD
1TB Secondary WD HDD (Used for installing games)
4GB G Skill Ares RAM
I tried to play a few games on my current machine, such as Dear Esther, Slender Arrival, Amnesia. But putting any of these games on a high setting really made the game chug and hardly playable.
For the RAM, I'm not sure if i should just get one more 4GB card to make it 8GB or if i should go for a brand new 16gb (2x8gb) Ram Kit.
From what ive seen across the net, people are saying that 8gb is enough and having 16gb would hardly make any difference?!?
Thanks for all your help guys!
Shoebox Case
Intel i5 3570k
64GB Crucial SSD
