Help! TV cable
Discussion in 'AV Receivers & Amplifiers' started by Bekka1988, May 9, 2016.
  1. Bekka1988
    Bekka1988
    May 9, 2016
    3
    4
    Surrey
    Just moved into a property which has a screw in cable
    How can I connect a normal ariel to this?
    Someone said I can get an adapter that you put onto the normal cable and then connect.
    Does anyone know what this is called??
    Many Thanks
  2. Member 581642
    Member 581642
    Jan 3, 2012
    11,106
    +2,501
    Do you have a picture, what is the cable attached to, and do you know that the cable definitely goes to an aerial not a satellite dish ?
  3. Bekka1988
    Bekka1988
    May 9, 2016
    3
    4
    Surrey
    It's a little box on the wall an.d NTL one.
    Unfortunately had sky out but can't get signal because of huge trees in garden!!
    He said can buy adapter just don't know what they are called
  4. Member 581642
    Member 581642
    Jan 3, 2012
    11,106
    +2,501
    Any you definitely have an aerial thats connected to it ?
    If so then probably F Type to Coax Aerial
    F Plug to Coax Socket
  5. Bekka1988
    Bekka1988
    May 9, 2016
    3
    4
    Surrey
    Yes definitely
  6. Rodders53
    Rodders53
    Dec 8, 2007
    4,842
    Bedford
    +854
    NTL: is the old trading name for Virgin Cable Television...
    So AFAIK it won't provide you with any usable signals unless you get a box from them and subscribe. In the good old days the analogue 1 to 5 channels were provided on their cable foc but now everthing is digital...
    You may need to get a terrestrial aerial installed?
