Help: Tuner audio passing through Scart on Panny 36PD50
Discussion in 'General TV Discussions Forum' started by DyManiX, Apr 6, 2005.
  1. DyManiX
    DyManiX
    May 29, 2002
    88
    3
    +7
    I setup my Dads Panny 36PD50 for him last night and noticed a rather
    annoying problem.
    If you watch a DVD (DVD Player plugged into AV4 running in RGB mode) you can still hear very quietly whatever channel you left the TV on before switching over to AV4.
    I remember reading something about this a long time ago so I am guessing it
    is a common problem.
    Any ideas how to get rid of it? Tried searching the forums here but cant find anything.
    I have tried changing the channel to an untuned one and you can hear hissing. We are using a Thor Scart lead.
    Thanks,
    Andy
  2. Tight Git
    Tight Git
    Mar 3, 2004
    6,332
    +597
    Buckbeak,
    Yes, this has been reported before, but I'm not sure how common it is.
    It seems to be cross-talk somewhere in the system and tuning to an "empty" channel (as you've done) usually does the trick.
    Just a thought, but have you tried one of the other AV inputs?
    Sorry I can't be more helpful.
  3. DyManiX
    DyManiX
    May 29, 2002
    88
    3
    +7
    Thanks for the reply.
    I havent tried the DVD in another RGB Scart yet (I think only 2 of them are RGB anyway). I have Sky in AV1 (which my Dad uses more than the DVD) and wanted to keep it that way if possible. Will give it a try anyway see if it works there.
    Come to think of it I dont think there is any noise when watching SKY so it might just be an AV4 problem :(
  4. billystevo
    billystevo
    Mar 13, 2005
    53
    9
    This happens on my Panny as well, TX- 36 PL 32 when DVD is connected to av4. It doesn't bother me because i use my Yamaha amp for the sound anyway, but would like to know the cause of it. :confused:
