Help--Toshiba TDP S9 is going dim
Discussion in 'Projectors, Screens & Video Processors' started by Charleytemple, Mar 27, 2006.
  1. Charleytemple
    Charleytemple
    Hi, I'm new here and I've searched already and haven't found an answer to this question: My Toshiba TDPS9 shows 67 hours on the lamp (It should to for 2000 hours,no?). But as of yesterday the projected image shows a yellow hue and is half the brightness. Under the "advanced settings" on the menu button are three different color bars. Pushing + or - on the first two bars slightly changes the color of the image projected, first two, but nothing changes when you push + or - on the "blue" bar.
    I'm working in Romania this year, and help here is not easy to come by. I would appreciate any ideas--especially those do not say I should fly home to New York and get a new lamp!
    Many thanks,
    Charlie
  2. bravogolf
    bravogolf
    Mar 24, 2006
    1,296
    +123
    This should help you :)
  3. Charleytemple
    Charleytemple
    Many thanks to Bragodoff for his suggestion. Meanwhile, a friendly soul from down the street suggested the problem might lie in the connecting cable, and he was right. I take back what I said about help being scarce in Romania!
    Charlie
