Help Tosh520 or Pioneer656a?
Discussion in 'Blu-ray & DVD Players & Recorders' started by lee28, Jan 25, 2003.
  1. lee28
    lee28
    Hi, ive just taken the plunge and bought a plasma tosh wp27b and want to get a good dvd player,
    But cant decide which is best the tosh 520 or the pioneer656a, perhaps you think that there are some others i should consider?
    I would like good sound and picture and will use component connections, i will also require it to be multi region.
    any good deals or personnel recomendations would be great.
  2. Markster
    Markster
    Alot to do with personally opinion this one, but if i had the tosh plasma I would team this up with the tosh510 for the best results imo.
