Help......too many to choose from!
Discussion in 'Camcorders, Action Cams & Video Making Forum' started by thejudge, May 26, 2004.
  1. thejudge
    thejudge
    Oct 28, 2002
    189
    19
    I'm looking at buying my first camcorder and have reached a sticking point............which one to buy.
    I'm aiming for the budget end of the digital market i.e. less than 300 quid. There are a few possibilities out there but i think i need further advice.
    I'm looking at the Sony TRV265 and the JVC GR-D23. The Sony is DV in and out which the JVC hasn't got but i would prefer a MiniDV rather than Digital8. Which would you recommend? Ideally i would go for the JVC GR-D53 but this may be slightly outside my budget. Does anyone have any experience with these camcorders? if so whats your advice? Is there any other models i should be looking at?
  2. MarkE19
    MarkE19
    Aug 10, 2002
    17,514
    Rainham Essex
    +2,515
    With a quick search on pricerunner I found 23 miniDV camcorders for under £300. Just personal choice, but I think that Sony make the best camcorders for quality and often features. But the best option is to actually hold a few and see which you like.
    Good luck,
    Mark.
