help - tomtom v3, v2 or ONE?
vaporand
im confused by the three models above and what version to get. i would like the item to update with the latest info. which one seems the best, never had satnav
thanks
sol_prior
thanks
The latest One is the XL version, and has a widescreen format.
The Version 3 is the same and has a more traditional square screen.
Buying these new should give you the same maps, the V1 and V2 will depend on how old these are.
Beyond that you should look at what features you would like to have, suach as hands free and traffic announcements. The best places to check these features is the tomtom website, or pocketgpsworld.com
vaporand
thanks for the reply, this link below outlines the v2 as being able to do most of what the v3 can with the user map feature added also.. think the v3 is still the choice mainly for the future updates and all...
http://www.find-tomtom-deals.co.uk/
then click on v2/v3
sneeks
TT One 3rd Edition is the latest version which runs the new v7 software making use of Map Share, the XL still runs v6 but can be updated online using TT Home to v7.
Currently able to be updated online using Home:
* TomTom GO 720 / 520
* TomTom ONE 3rd Edition
* TomTom ONE 2nd Edition (only those with serial numbers starting with Z1, Z2 or Z3)
* TomTom ONE XL
Podcast: Reported HDMI 2.1 bugs, Audiolab Amp & LG LED Projector reviews + Best of the Month
