Help to find speaker cable bi-poled or not
Discussion in 'Cables & Switches' started by g1smo, Jul 29, 2005.
  1. g1smo
    g1smo
    Jul 16, 2005
    38
    hi peeps all new to this and need speaker cable for my set up, do i use bi-poled for the fronts? as the speaker are bi-poled and what type size etc etc
    any help would be great and any links for buying then cable/prices
    cheers
  2. loadsofleads
    loadsofleads
    Hi, Bi-wiring is a contentious subject, some say it makes a vast difference and others say it is a waste of time. My own speakers are bi-wired and I personally think it is slightly better, but does not make a world of difference. If your speakers are capable, try it and see if you can hear a difference, otherwise stick to twin-axial cable. Bi-wired cables will be thicker as you have four cables instead of two, and as it's double the size it will usually be double the price !! :thumbsup:
