help to find fujifilm fine pix 1300 driver
Discussion in 'Photography Forums' started by soooperguy2006, Jan 2, 2007.
  1. soooperguy2006
    soooperguy2006
    Hi There, i have a fujifilm(old) finepix1300 digital camera, used it to take xmas family pics, got home computer crashed and i lost everything , and had to reformat. Unfortunately i didnt have the driver disc , and i cannot locate any software downloads,:mad: :mad: :mad:
    Can anyone help me ? i contacted fuji direct and was told to ask on here , HELP if you can :lease:
  2. nry
    nry
    Jan 1, 2006
    332
    28
    Carlisle
    +23
    If you have a USB-based camera (according to the FujiFilm site your camera is USB) then providing you have Windows XP or a Mac with OSX you probably don't need a driver, plug it in to the PC via USB and it should install drivers on its own and then let you use the 'Scanner and Camera Wizard' to download the pictures.
    Otherwise, the FujiFilm site does have plenty of downloads:
    http://www.fujifilm.com/products/digital/download/01/index.html
    Though you cannot get the FinePix viewer software as a download, only updates for previous versions, i.e. you'd need your CD and original version to let these updates work/install.
