Help to find alternative
Discussion in 'What Is The Best TV For You?' started by Psikis, May 3, 2016.
Tags:
  1. Psikis
    Psikis
    May 24, 2008
    84
    +12
    Decided to go for 55cx802b today. Went to Richer Sounds in Chiswick, not in stock (couple in other stores at the other end of where i live).
    Went to Currys, sold out !
    Any good alternatives to that tv ? How about newer models ? Up to 1000 pounds.
    Looking for Flat, BackLit, similar response time. Will be used to ps4, tv (in HD), movies.
    Thx a lot.
  2. Psikis
    Psikis
    May 24, 2008
    84
    +12
    Update: All sorted. Drove 55miles one way and picked it up. It was close call to fit it into the car :))
