Question Help to find a short throw low res Projector
Discussion in 'Projectors, Screens & Video Processors' started by sluprostom, Apr 26, 2018.
  1. sluprostom
    sluprostom
    Apr 26, 2018
    Germany
    Hi, I'm doing an art project where I'm using a projector as a light source through pretty thick transparent fabric. I've read up on the terms and think I know what I need, also looked at projectorcentral but thought I'd ask here since you guys might know more or have good tips :)
    It seems 2000 lumens are enough to shine properly through the fabric and the way the material diffuses the light makes resolution a non-issue, 420p would be sufficient. Noise levels also doesn't matter, but I need a pretty short throw distance of 0.5 or less as the space is very crammed.
    TL;DR, I'm looking for a >2000 lumen, low resolution (picture quality doesn't matter), >0.5 throw projector, preferably as cheap as possible. Any tips for models to look for in the second hand markets?
  2. columbo81
    columbo81
    Oct 10, 2008
    35
    If you're not projecting an image I don't think the throw distance will matter, it'll purely be whether it's bright enough for what you need.
  3. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    28,360
    The Borders
    +3,432
