help to connect plasma panny 42" please
Discussion in 'Plasma TVs Forum' started by rob virgo, Jun 15, 2005.
  1. rob virgo
    rob virgo
    Nov 27, 2004
    217
    16
    its a panny with s-vid/composite and 5 bnc.
    i need to connect pioneer one box system and sky.cant get the picture from both sources but can get sound.
    i got an rgb to s-vid to go from sky to panny and scart from dvd one box to sky.
    what am i doin wrong
    rob
  2. rob virgo
    rob virgo
    Nov 27, 2004
    217
    16
    bttt
  3. hornydragon
    hornydragon
    Dec 19, 2001
    28,291
    +1,217
    OK i assume you have the dual slot board?
    and currently you have DVD>sky(via scart to scart lead) and from Sky>plasma(Scart to S-video lead? or active converter???)
    does pio all in one have S-video or component output?
  4. rob virgo
    rob virgo
    Nov 27, 2004
    217
    16
    hi ,
    pion does not have any other connection than the scart i mentioned.this all in one is the dvd to if i wasent clear
    rob
  5. hornydragon
    hornydragon
    Dec 19, 2001
    28,291
    +1,217
    OK does the scart offer an S-video output? (pioneer all in one DVD, that is) cheapest option to get a picture is probably S-video for DVD if possible and the either a sync blaster or an RGB+S cable for Sky, PAnnys dont reallt like a CVBS sync but you should get a picture
