Help to choose best cabling ..... Pls
Discussion in 'Projectors, Screens & Video Processors' started by errm, Dec 28, 2004.
  1. errm
    errm
    I have the following:
    Loewe Anaconda TV
    DENON AVR 3805
    DENON DVD 3910
    HS50
    HCPC
    I forgot my digibox
    Could you tell me the best cabling and how to interconnect the above (DVI, HDMI, ??)
    Thanks a lot..
  2. UrbanT
    UrbanT
    Jan 6, 2002
    12,877
    Aldershot, Hants
    +3,036
    errm, a quick question. Why are you using an HCPC as well as a DVD player?
  3. errm
    errm
    PC: Just to see some stills and video recorded with my camcorder and stored in the PC
  4. KraGorn
    KraGorn
    Aug 30, 2003
    4,740
    68
    Warrington
    +27
    I'd suggest you ask Joe at The Media Factory, high quality cables and other installation kit like switches. Not cheap, but if you're after quality you'll get excellent advice. :)
