Help to choose a new plasma TV
Discussion in 'Plasma TVs Forum' started by lui, Mar 18, 2006.
  1. lui
    lui
    All,
    could you help me choose a good Plama TV? I am sure you will have the best suggestion for me!
    Here are the 3 choices I am currently thinking of: 1- Hitachi 42PD7500; 2- fujitsu P42HTA51ES (from richer sound); 3- Pioneer PDP-436SXE.
    All I am interested is the quality of the image (in particular for watching DVDs and cable).
    Can anyone also recommend a good DVD player for the TV? And where is the best price for TV and DVD player?
    Thank you very much for your advise!
    Lui
  2. lui
    lui
    thanks!
  3. john_g_c
    john_g_c
    By no means am I an expert on this (far from it) but I looked at the Panny PV500 and the Pioneer 436XDE, next to each other, in several shops, over several weeks before choosing the Pioneer.
    The Panny has a very crisp image but the Pioneer had a little something else that I could only describe as a "cinema" quality.
    You'll get lots of differing opinion though, I'm sure. At the end of the day, when spending that kind of money, you have to trust your own opinion.
    Look at them all and decide which YOU think has the best PQ!
    :thumbsup:
  4. choddo2006
    choddo2006
    Dec 30, 2005
    8,528
    +542
    Surely the Pioneer is the only choice to make out of those 3? Or is it a trick question?
  5. SYNCHRO_MAN
    SYNCHRO_MAN
    Feb 26, 2006
    29
    if you`re spending that kind of money get some demo`s from specialist dealers ,don`t judge by what you see in the likes of curry`s/comet and the like.I spent about 4wks reviewing and reading mags and forums eventually went for the Pioneer 436xde the best IMHO.If your planning on putting it on the wall remember the 436 is controlled via a media box so you only have 2 cables going to the screen everything else plugs into the media box.
    good luck
    :thumbsup: :smashin:
