Help Titling Scenes on Panasonic DMR-E100H
Discussion in 'Blu-ray & DVD Players & Recorders' started by Bjay, Aug 23, 2005.
  1. Bjay
    Bjay
    After reading the manual over and over again cannot for the life of us work out how to title scenes.
    Have recorded the video to HDD and split into scenes, now wish to title each scene and then transfer to DVD disc, but cannot work out from the manual how this is done!
    :lease:
  2. RAB67
    RAB67
    Aug 21, 2005
    177
    +8
    What do you mean by "Scenes"? Have you split you recording into separate titles or chapters?
    You can't name individual chapters
  3. Bjay
    Bjay
    In the manual Advanced Operations Using Play List to edit programmes. Here it tells you how to edit a playlist and create Scenes.
    At the very end of this operation is says Enter the title (page 30), this is as far as we get. Any more advice will be appreciated.
  4. Kevo
    Kevo
    Aug 23, 2001
    5,398
    Manchester
    +149
    You can't title each scene. The manual is referring to a title for the whole playslist you created. You can then transfer this playlist to DVD, it will have this title and show up on the main menu as that.
