Question Help thinking about moving from Sky
Discussion in 'Freeview & YouView' started by Mike78695, Jul 16, 2015.
Tags:
  1. Mike78695
    Mike78695
    Jun 29, 2014
    174
    +10
    Hey guys so I am thinking about moving from sky to BT as they are gonna have the sports in 4k. My only problem is the aerial connection for the freview part of thinks dose anyone know of a workaround for this ? such as using an indoor aerial or using my sky dish?
    thanks
  2. TJT1
    TJT1
    Jul 29, 2011
    4,826
    East Sussex, UK
    +1,139
    Your sky dish won't work for Freeview and whether you can use an indoor aerial depends on how close to the transmitter you are.
  3. Mike78695
    Mike78695
    Jun 29, 2014
    174
    +10
    I spoke with bt and they said an inhouse aeiral will work is this correct ?
  4. TJT1
    TJT1
    Jul 29, 2011
    4,826
    East Sussex, UK
    +1,139
    Well, if they say so, they must be right :rolleyes:
    Buy one from B&Q, unpack it carefully then take it back if it doesn't work.
    Indoor aerial performance is so variable that it is virtually impossible to predict unless you live really close to the transmitter.
