Help! - THIN speaker cable for under carpet
mark.carline
I am in the middle of doing up my front room and before the underlay and carpet does down I wanted to pull some speaker cable under the underlay.
Does anyone here know of any suppliers of flat speaker cable ?
I am not really that bothered about getting the best quality (its only a small living room 5.1 setup) so somthing cheap but very thin will do.
Paste links on here if you can
Thanks!!!
[email protected]
Eitzel
caleb
Nordost make a VERY THIN series of speaker cables that are almost hidden under a carpet.
Van den Hull also make a flat speaker cable (bi-wire also) but thius is more noticable.
CALEB
C
Coops666
Thanks for the info Mark - I've just ordered some of the QED cable from Superfi - you saved me lots of search time!
Paul
Podcast: CES '22 TV Announcement Round-up, Plus, Most Anticipated Movies of 2022 and More...
