Help - Technomate 1500. No picture/sound
Discussion in 'Satellite TV, Sky TV & FreeSat' started by neilrlsmith, Sep 2, 2007.
  1. neilrlsmith
    neilrlsmith
    Jun 29, 2007
    398
    +13
    Hi - just chaned TVs and the now I cannot get picture/sound from receiver.
    The connection is scart to scart and I have double checked that the inout on the TV is correct and the cable is working properly. The aerial lead is plugged in to LNB out so thats right also.
    I have switched on and off from standby several times and nothing.
    Is there some magic button on the remote to get the scart active or something?
    Thanks!
  2. Chris Muriel
    Chris Muriel
    Jun 14, 2002
    7,280
    Manchester
    +763
    What (make and model) TV ?
    Is there a source-switch menu for the TV - usually a button on the TV remote control that cycles through SCART/phono/Auxiliary/Tuner etc. inputs ?
    Chris Muriel, Manchester
  3. neilrlsmith
    neilrlsmith
    Jun 29, 2007
    398
    +13
    Thanks Chris. I'll try to not make this long winded...
    I have a Pio 508. Everything is connected to my amp and then the amp is connected to the screen. Therefore the input on the TV never needs to change.
    The other 2 things that connect to the amp are by HDMI leads (and obviously they work).
    The only thing the TV does not recognise is the Technomate.
    I even tried connecting the technomate directly to the TV (via scart obviously) - and still no picture.
    The dish/receiver worked yesterday so I cant believe they're faulty.
