Help!! Sub Woofer Cabling
Jigga Jackson
Hello All,
I've got a Yamaha DSP-AX757SE amp and want to connect a Mission Sub (i think its an SE 7383... maybe) to it. But problem is, the sub, has loads of ports to conntect stuff to and i haven't a clue where to connect a cable to and what kind of cable i need... Can anyone please help me, i'm proper struggling!!!
(It probably would have been better if i found a pic of the back of my sub!)
http://www.superfi.co.uk/images/DSPAX757SE-rear-1400x532.jpg
Heres back of amp. am gonna connect somethign to pre out sub woofer port, but i don't know what kind of cable, cos my sub has a couple line level in ports and then a few "clip ports" like those shown in the picture above. (See the part that says Presence!)
Any help, woud be greaT...
paulst10
Hi, you need a single RCA - RCA cable going from your amps subwoofer pre-out (middle of the amp) to one of the subwoofers low level inputs (doesn't matter which one) :thumbsup:
Jigga Jackson
Thanks,
:thumbsup: thats kinda helped. Does it matter what make of cable. Can you suggest a decent make?:lease:
paulst10
Thanks,
You don't have to go too over the top as long as it has good screening .. many here seem happy with Marks cables in the powerbuy forum http://www.avforums.com/forums/cabl...oofer-cable-canares-finest-quality-lv77s.html
Although if you didn't want to spend that much (not sure what length you need) I would take a look at other brands as there may be a few lower priced cables from places like this Subwoofer Cables - Other cables - HiFiCables.co.uk or on ebay etc! :smashin:
