help stream movies form pc external hard drive to ps3
hookstar
hello there i just rebooted my pc and can now not sync the ps3 back up to the external hard drive on my pc befor that i had it running sweet but now it wont pick up anything appart from my pc but no hard drive any help will do thanks
Eyewhy
Are you using TVersity. If so, check the drive letter on the external HDD. I had an issue where my external HDD always came up as E: so that is what the destination was set to on Tversity but for some reason recently, it has started to come up as F: meaning Tversity doesn't find it.
Hillskill
Moderator/Games Reviewer
I know its obvious but thought I would run it by you. Have you started MP11 since your reboot ?
