thudspud
Hello
I have just bought myself the Sony DVP-NS900 Multi Region from Richer sounds for £249.99 but I think it might be faulty
When watching a DVD, at the bottom of the screen, about 2cm up, there is a thin grey bar about 1cm think (on my 25" toshiba 4:3 TV)
On RGB it goes all the way across the screen, and on S-Video and composite (either through a scart lead or separate leads) the bar is still there although it has a gap about an inch wide exactly in the middle!!!
I have moved the picture down as far as I can get it but it won't go down far enough to mask it out
The stange thing is that if you don't have a disc in the machine and it just displays the sony startup screen the grey bar isn't there but as soon as it goes into 'play' mode the bar suddenly appears.
ALSO, Just noticed that the grey bar doesn't appear if you play a 4:3 film, only on widescreen films!!!!!
The TV is a Toshiba 2505DB.
Any help would be much appriciated as I really don't want to take it back as it was the last one in stock and I doubt I will get another!
Chris
Chris
