Help! Speakers for Bathroom needed
Discussion in 'Home Cinema Speakers' started by Kramo, Dec 3, 2004.
  1. Kramo
    Kramo
    Hi all,
    I'm looking for wall mounted speakers suitable for a bathroom. Its a large room with no condensation or moisture problems (so hopefully don't need outdoor speakers!).
    Preferrably I'd like small cube type speakers for 2 upper corners of the room
    Looking at Bose Cubes and Wharfedale Modus. Although nice and small I hear the Bose cubes will not deliver any base so would need a subwoofer, is that true?
    Are there any other speakers I should, check out? I don't want bookshelf speakers as they are a bit too large.
  2. Mylo
    Mylo
    Mar 13, 2003
    5,565
    +372
  3. Kramo
    Kramo
    Thanks Mylo, hadn't considered a sub.
    Anyone got opinions on Bose cubes bass reproductions?
    K
  4. barnythebear
    barnythebear
    Jul 6, 2004
    152
    leicestershire
    Part of the mid range and bass on the Bose comes from the sub so you would need the whole kit
  5. barnythebear
    barnythebear
    Jul 6, 2004
    152
    leicestershire
    Should have said when I posted before. Bose do some other smallish speakers with a full range. However, until you get up to the, I think it's 301's, they are not that good.
  6. barnythebear
    barnythebear
    Jul 6, 2004
    152
    leicestershire
  7. Docta teef
    Docta teef
    Nov 21, 2003
    1,262
    Manchester
    +56
