[email protected]
Established Member
Just took my first dive into a proper system with a Denon 1507 and Tannoy FX 5.1 Speakers. However first problem on set up is that my existing speaker stands are nothing like what the Tannoy needs. Current ones have holes at the back and the Tannoy's have the fixing on the base. Can anyone recommend some cheapish stands as i have blown my budget already thinking my current ones would suffice.
Thanks wolfy!!!!!
Thanks wolfy!!!!!
